ASA8.03 NAT Problem
Nov 21st, 2007
Hi !
I have a problem with my ftp server in the DMZ. I am not able to reach it from the internet. I have tried many different nat rules and acces list, but can't get it to run. When I do a paket trace with the adsm, it say that everything is fine - but still no contact. What am I doing wrong?
Here comes the config:
ASA Version 8.0(3)
names
interface Ethernet0/0
nameif Outside
security-level 0
ip address 62.x.x.76 255.255.255.248
interface Ethernet0/1
nameif Inside
security-level 100
ip address 192.168.100.1 255.255.255.0
interface Ethernet0/2
nameif DMZ
security-level 50
ip address 192.168.110.1 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
boot system disk0:/asa803-k8.bin
ftp mode passive
dns server-group DefaultDNS
domain-name default.domain.invalid
access-list Outside_access_in extended permit tcp any eq ftp host 62.206.196.77
pager lines 24
logging enable
logging asdm informational
mtu Outside 1500
mtu Inside 1500
mtu DMZ 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-603.bin
no asdm history enable
arp timeout 14400
global (Outside) 101 interface
global (DMZ) 101 interface
nat (Inside) 101 0.0.0.0 0.0.0.0
nat (DMZ) 101 192.168.110.0 255.255.255.0
static (DMZ,Outside) 62.x.x.77 192.168.110.10 netmask 255.255.255.255
access-group Outside_access_in in interface Outside
route Outside 0.0.0.0 0.0.0.0 62.206.196.73 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.168.100.0 255.255.255.0 Inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
no threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
Any help is greatly appreciated. Thank you!
best regards
Fritjof
JORGE RODRIGUEZ Wed, 11/21/2007 - 14:30
  • Green, 3000 points or more
try changing your static nat as :
no static (DMZ,Outside) 62.206.196.77 192.168.110.10 netmask 255.255.255.255
static (DMZ,Outside) tcp 62.206.196.77 21 192.168.1.10 21 netmask 255.255.255.255
[edit] in case inbound does not hit the ftp server change acl as:
access-list Outside_access_in permit tcp any 62.206.196.77 eq 21
access-group Outside_access_in in interface outside
Jorge
