PIX515 no console access
Nov 21st, 2007
I have a pix 515 that was upgraded to 6.3(5) and pdm3.04.
The device works fine for one day and then stops working. The power supply is on, the Ethernet interfaces give link but there is not response and no console access also, during boot process there is nothing on the console.
Would the upgrade creates a problem or it was just bad luck on the hardware?
Thanks.
andyjames Fri, 11/30/2007 - 07:46
Are you getting the initial boot screen when the PIX boots?
I had a similar problem after upgrading, i forget to which version. My problem was the CMOS battery, evrything looked to be working but nothing was.
If you take the battery out, clean and replace it will usually start. If it does get a new battery as it won't last for long.
HTH.
Andy.
