wr mem - privilege Level issue - Pix Firewall
I have setup specific user level privileges for our Juniors to add and modify acl lists. I would like them also to issue the wr mem command from there level of access. But when l test this command under there level l get the following error :
acmi# wr mem
Building configuration...
Error executing command
[FAILED]
It maybe due to the fact that this level of access is denying them access to the flash or something to do with the cryptochecksum.
Here below are the current privilege levels l have setup.
privilege cmd level 2 mode exec command configure
privilege cmd level 2 mode exec command disable
privilege cmd level 2 mode exec command write
privilege show level 2 mode exec command access-list
privilege cmd level 2 mode configure command name
privilege cmd level 2 mode configure command access-list
It is a Pix 525UR with Version 7.2(2)
Thanks Simon Galloway
htarra Tue, 11/27/2007 - 14:46
  • Bronze, 100 points or more
Privilege-level command tracing is provided through the PIX Firewall syslog, and privilege configuration updates are displayed in the show version command output. User authentication may occur either locally or through a TACACS+ server. This error is occurning because cryptochecksum is mismatching.
