How can integrate CCM with IPCC Express
Nov 21st, 2007
I have CCM 4.3 and i want integrate it with IPCC Express 4.1.
Can you help me to find how can I make this integration between these two components.
I wait for your feedback
Best Regards.
Overall Rating: 3 (1 ratings)
lpezj Thu, 11/22/2007 - 02:31
You can take a look to the documentation, regarding IPCC Express 4.1 in this link:
Basically, you will have to create CTI Route Points, as points to send calls to the CallCenter, CTI Ports, they are the physical ports used by the IPCC Express to queue calls or IPIVR applications, Callmanager users to monitor all the above components and the agents physical phones.
Take a look to the Installation Guide.
Hope this helps,
Juan Luis
