Connecting my Core Switches
lee.cullivan
I am in the middle of a network upgrade and I am looking for the best way to connect my two Core switches. I have two 4506s in a collapsed core environment. These switches currently are connected via layer 2 links (not port channeled) to each other on g1/1 and g1/2 creating a spanning tree instance (rpvst+). My access layer consists of 17 closets with stacked 3750s. For odd vlans, core2 is the root primary, for even vlans, core1 is the primary.
My question is, am I okay with the two separate gig links between cire1 + core2 or should I port-channel them to make a single 2Gb link?
Any advice is appreciated. Thanks,
lee
Edison Ortiz
Currently, you have fault tolerance with the two separate GigE links but etherchannel will give you that and bandwidth aggregation so I say, GO FOR IT ! :)
