11-21-2007 08:36 PM - edited 03-13-2019 04:44 PM
Good day, we have a Cisco High-Density Analog And Digital Extension Module for Voice and Fax (EVM-HD)for our new Cisco 3845 Router. My question is, what did you call about the port connection at the back of the Module, its like a female serial connection 25 pins. Is it shipped with a cable to be connect on that module? I will wait for your answer, thanks.
11-22-2007 01:34 AM
It is called a 50 pin RJ 21 connector. The cable is not shipped with module - check table 5 at
http://www.cisco.com/en/US/products/ps5855/products_data_sheet0900aecd8016c1c6.html
11-22-2007 05:57 AM
Hi Mahmoud,
Just to add a note to Mauliks good info (5 points for this nice work Maulik!)
Connecting Cisco High-Density Extension Modules to the Network - ***Make sure you order the RJ21 with a "MALE" connector***
The Cisco high-density extension module is connected to a distribution frame or patch panel with an RJ-21 cable.** RJ-21 cables are not provided with the network module.
Here are the parts you would need to connect to a 24 port rack mounted Patch Panel (without needing to terminate the cable with Bix or 110 connecting tools).
Cisco RJ21 Cables
http://www.stonewallcable.com/product.asp?dept%5Fid=102&pf%5Fid=SC%2D9754
24 Port with RJ21 Male
http://www.cablingsys.com/iteminfo.asp?productcode=017-224M62U
These are just examples :) I have not checked pricing $$
Hope this helps!
Rob
