PPP Over farme-relay
Answered Question
Nov 21st, 2007
  • Cisco Employee,
Hi Team,
I was working on PPP over FR other day and somehow, I couldnt get it setup and working properly.
here is the setup :
R1 --- FR---R2, using physical interfaces.
R1 config:
username R2 password cisco
int virtual-template 1
ip add 10.1.1.1 255.255.255.0
encap ppp
ppp auth chap
int s 0/0
encap frame
frame int-dlci 102 ppp virtual-temp 1
R2 config:
username R1 password cisco
ip add 10.1.1.2 255.255.255.0
encap ppp
ppp auth chap
int s 0/0
encap frame
frame int-dlci 201 ppp virtual-temp 1
Fr PVC status= UP
Virtualtemplate= Down, Which is OK as it will always be down/down
Virtual access 2 = Down
PPP status: LCP down, Closed.
Any inputs on this would be appreciated.
-amit singh
Correct Answer by Edison Ortiz about 9 years 6 months ago
If it doesn't work, turn debugging on ppp authentication.
Rack1R1#debug ppp authen
PPP authentication debugging is on
Rack1R1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Rack1R1(config)#int s1/0
Rack1R1(config-if)#shut
Rack1R1(config-if)#end
Rack1R1#
*Mar 1 00:22:30.887: %LINK-5-CHANGED: Interface Serial1/0, changed state to administratively down
*Mar 1 00:22:30.895: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
Rack1R1#
*Mar 1 00:22:31.087: %SYS-5-CONFIG_I: Configured from console by console
*Mar 1 00:22:31.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
*Mar 1 00:22:31.895: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
Rack1R1#conf t
Rack1R1(config-if)#no shut
Rack1R1#
*Mar 1 00:22:42.271: %SYS-5-CONFIG_I: Configured from console by console
*Mar 1 00:22:43.047: %LINK-3-UPDOWN: Interface Serial1/0, changed state to up
*Mar 1 00:22:43.075: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Mar 1 00:22:43.079: Vi2 PPP: Using default call direction
*Mar 1 00:22:43.083: Vi2 PPP: Treating connection as a dedicated line
*Mar 1 00:22:43.087: Vi2 PPP: Session handle[7000023] Session id[40]
*Mar 1 00:22:43.087: Vi2 PPP: Authorization required
*Mar 1 00:22:43.335: Vi2 CHAP: O CHALLENGE id 40 len 23 from "R1"
*Mar 1 00:22:43.439: Vi2 CHAP: I CHALLENGE id 40 len 23 from "R2"
*Mar 1 00:22:43.451: Vi2 CHAP: Using hostname from interface CHAP
*Mar 1 00:22:43.451: Vi2 CHAP: Using password from AAA
*Mar 1 00:22:43.455: Vi2 CHAP: O RESPONSE id 40 len 23 from "R1"
*Mar 1 00:22:43.459: Vi2 CHAP: I RESPONSE id 40 len 23 from "R2"
Rack1R1#
*Mar 1 00:22:43.467: Vi2 PPP: Sent CHAP LOGIN Request
*Mar 1 00:22:43.475: Vi2 PPP: Received LOGIN Response PASS
*Mar 1 00:22:43.483: Vi2 PPP: Sent LCP AUTHOR Request
*Mar 1 00:22:43.487: Vi2 PPP: Sent IPCP AUTHOR Request
*Mar 1 00:22:43.495: Vi2 LCP: Received AAA AUTHOR Response PASS
*Mar 1 00:22:43.499: Vi2 IPCP: Received AAA AUTHOR Response PASS
*Mar 1 00:22:43.503: Vi2 CHAP: O SUCCESS id 40 len 4
*Mar 1 00:22:43.623: Vi2 CHAP: I SUCCESS id 40 len 4
*Mar 1 00:22:43.635: Vi2 PPP: Sent IPCP AUTHOR Request
Rack1R1#
*Mar 1 00:22:44.047: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
*Mar 1 00:22:44.623: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
Overall Rating: 5 (1 ratings)
Edison Ortiz Wed, 11/21/2007 - 22:08
  • Hall of Fame,
    Founding Member
If the router's hostname isn't R1 and R2, you must send the hostname in chap with
ppp chap hostname
command.
BTW, I copied and pasted your config and worked here - the only thing I changed was adding the ppp chap hostname since my router's hostname wasn't R1 and R2.
Amit Singh Wed, 11/21/2007 - 22:15
  • Cisco Employee,
Thanks Edison for the reply.
I think my hostname was the same as used in the UN/PW. let me go ahead check it right away and will rate the post. Thanks buddy !!
-amit singh
Correct Answer
Edison Ortiz Wed, 11/21/2007 - 22:23
  • Hall of Fame,
    Founding Member
Rack1R1#conf t
Rack1R1#
Rack1R1#
Rack1R1#conf t
Rack1R1#
Rack1R1#
Rack1R1#
Amit Singh Wed, 11/21/2007 - 22:31
  • Cisco Employee,
It has worked for me without the "PPP Chap hostname ". I dont know what I missed out earlier, but its working for me now. :-)
-amit singh
