Warning message
add a host to CSA MC to manage
Nov 21st, 2007
hi all,
I have Group WEB and MAIL. Every group has two server such as WEB has WEB_1 and WEB_2. Now I has a new server (named WEB_3) and I want CSA MC to manage WEB_3. I do following steps:
1. Download the kit of group WEB to WEB_3
2. Install CSA at WEB_3 (and install successful)
However, when I connect to CSA MC, I don't know
1. Add host WEB_3 to CSA MC to manage
2. Add host WEB_3 to group WEB
If you know, please answer me early. I have a licences for CSA.
Khang
Overall Rating: 5 (1 ratings)
mylove142 Thu, 11/22/2007 - 23:07
hi all,
I log in to WEB_3 and I see the log (/var/adm/)
Nov 21 10:08:13 Frontmail03 CiscoSecurityAgent[6886]: [ID 702911 local4.info] Failed transaction, url=https://qtsc-mc:5401/csamc52/agent, curlerr=7 (Connect failed).
Nov 21 10:08:13 Frontmail03 CiscoSecurityAgent[6886]: [ID 702911 local4.info] Registering with server CSA MC, Failure (1)
Nov 21 10:08:13 Frontmail03 CiscoSecurityAgent[6886]: [ID 702911 local4.info] Will retry to register in 3600 sec (Poll to expedite it)
I have a license for 10 agents, I have already installed license at CSA MC.
If you know why the host can't register to CSA MC, please answer me early.
Thank you very much,
Best regards,
Khang
santukumar Thu, 11/22/2007 - 23:46
first install the agent kit in the client from mc and restart it. After that automatically registered to the server. When it register, then u can only add it to the group.
mylove142 Fri, 11/23/2007 - 00:13
hi all,
I use FWSM, now, I must open which services or port from CSA MC to CSA agents? So, CSA Agents can connect to CSA MC.
Thank you
pmccubbin Fri, 11/23/2007 - 04:36
  • Silver, 250 points or more
Access to the CSA MC from the client on a DMZ requires the following ports to be open on the Firewall:
Source Destination Port Protocol
80 TCP
443 TCP
5401 TCP
5401 UDP
Note: port 443 is for management only and sends you to the login page.
Hope this helps.
mylove142 Fri, 11/23/2007 - 17:53
ok, I have configure the policy from CSA agent to CSA MC like you and it operates. Thank for your supports.
I have already added host to CSA MC.
Best regards,
Khang
