11-22-2007 01:03 AM
I have 2 locations, each with 2 6509+ACEs installed. I need some contexts to failover to the local switch, and some to failover to the other site. However, only one peer can be configured. Is there a way around this limitation?
Solved! Go to Solution.
11-22-2007 01:22 AM
you can't fail over across sites and currently only 1-1 failover is supported.
Gilles.
11-22-2007 01:22 AM
Gilles.
11-22-2007 01:28 AM
Thanks Gilles.
The sites will have direct fibre connection, not routed, so that should be OK yes?
11-22-2007 03:59 AM
in this case i think you need side selector to load balance btween data centers
11-22-2007 04:02 AM
Naturally that would be ideal, but we don't have one. So ospf costing and the direct links to carry FT vlan traffic will work?
11-24-2007 10:54 PM
danger m,
FT ACE modules must be layer 2 adjacent on the FT VLAN.
marty
11-25-2007 12:37 AM
They will be. The sites are not far apart, just different buildings on a campus. We will have fibre modules and direct links *not* going over the core. i will be trunking the ft vlans across. I am considering recommending GSS though, as with the current set up I will have to advertise the same networks from 2 different CEs.
