CSM - Server Initiated Connection Question.
Nov 22nd, 2007
Doing a config for client to server looks straight forward, but not clear on the other direction, as in, if a conectiion gets initiated from server to outside - server to client
Do I need to NAT? or Will it just use the virtual address I define in the other direction as its source?
Is there any configuration example?
Overall Rating: 5 (1 ratings)
Gilles Dufour Thu, 11/22/2007 - 07:28
if you need to nat a connection opened by the server, look for the 'static nat virtual' command.
Gilles.
astanislaus Thu, 11/22/2007 - 13:25
Gilles,
Thanks.
Is there an example config somewhere or do I just look in the software configuration guide.
Alphonse
Gilles Dufour Fri, 11/23/2007 - 01:05
your config looks good.
Get a sniffer trace of the csm portchannel so we can see what the csm does with your real server initiated conection.
Gilles.
astanislaus Sun, 11/25/2007 - 06:45
Gilles,
Sniffer trace shows the real serve's IP address sending the ping, but no ping from the nat'ed IP address. My customer did the trace. He did not send me the trace, but he is saying that he can see two packets from the real server's IP address for every ping. Why two?
