Mobility Manager Pickup on Mobile
Nov 22nd, 2007
I'm configuring Mobility Manager 1.2 with CCM 4.3 and H.323. There is also H.323 overlp sending configured.
If I configure the RP to modify the caller id, I hear only MoH on the mobile.
I have configured only mrgls and device pools without moh. So I think the moh is streamed from the phone which is shared with the cti port.
I think it could be a problem with partitions and CSS. I have tried everything, but no luck.
Any advise?
Cheers
c.hennrich Wed, 11/28/2007 - 07:52
thanks, I tried that and my config was correct.
The only thing I was missing; I had my VPN Client open and it catched all CTI traffic and I tried it with my IP Communicator.
Aft I found that out and closed the VPN everything worked very well.
Cheers
