resolve hostname in TCL script
Nov 22nd, 2007
Basic Question:
How can I do a "nslookup <hostname>" in an eem tcl ?
Background:
I need to modify the running-config by putting the same (!) ip address at several places (crypto map peers, access-lists, routes).
No Problem. Basically that already works when using IP adresses.
But now the IP adress has to be resolved by DNS. The responsible DNS server uses Round-Robin-DNS and delivers another IP with every answer.
If I use the hostname in the cli_exec, the hostname is parsed to IOS,
and IOS resolves the hostname to a different IP with every "cli_exec"; leading to different IPs in the running config.
Is there a dns command or lib available in the IOS-TCL ?
Joe Clarke Thu, 11/22/2007 - 09:58
There is no DNS library for IOS TCL (and currently no UDP socket support to make your own). But you could do something like:
set output [exec "ping ip [info hostname] repeat 1"]
regexp {Echos to ([^,]+)} $output ignore ip
puts $ip
Joe Clarke Thu, 11/22/2007 - 23:09
Sorry, I missed the keyword "eem" there. The same method will work, but you will need to modify things slightly for EEM. I wrote an EEM CLI wrapper library to help with these things which can be downloaded from http://forums.cisco.com/eforum/servlet/EEM?page=eem&fn=script&scriptId=441 . Using that library, the above would become:
set cmd "ping ip [info hostname] repeat 1"
set output [run_cli [list $cmd]]
# $ip now holds the IP address
ffischer Fri, 11/23/2007 - 01:27
Thanks, Joe.
We already had the "IOS ping command" idea...
As unfortunateley there seems to be no better solution without a resolver/dns lib, I will try to implement that.
btw:
Does a IOS tcl-command/tcl-library reference exist ?
Can it be found anywhere in the vastness of the CCO ?
