AS5350 as a VOIP Gatekeeper
rasankalakmal
I have Cisco AS5350 with me. Im trying to configure this as a Gatekeeper. But it supports only the "Gateway" command and "Gatekeeper" command is not available. Can anyone tell the reason for this.
Thanks in advance.
Cisco offers a Voice over IP gatekeeper called the Multimedia Conference Manager, which is an H.323-compliant program implemented as part of the Cisco IOS software. The Multimedia Conference Manager software can run on Cisco 2500 series, Cisco 2600 series, Cisco 3600 series, and Cisco MC3810 Multiservice Access Concentrators.
Please take some time to go through the PDF tech notes on cisco web site,
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_programming_reference_guide_chapter09186a00801fc95f.html.
7 Replies 7
paolo bevilacqua
Which exact IOS image are you running ?
Pls find sh ver.... output
IOS (tm) 5350 Software (C5350-IS-M), Version 12.2(15)T1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 27-Mar-03 07:27 by ccai
Image text-base: 0x6000895C, data-base: 0x61600000
ROM: System Bootstrap, Version 12.2(1r)1, RELEASE SOFTWARE (fc1)
BOOTLDR: 5350 Software (C5350-BOOT-M), Version 12.2(2)XB2, EARLY DEPLOYMENT RELE
ASE SOFTWARE (fc1)
cloud.009 uptime is 1 week, 4 days, 16 hours, 49 minutes
System image file is "flash:c5350-is-mz.122-15.T1.bin"
cisco AS5350 (R7K) processor (revision T) with 131072K/65536K bytes of memory.
Processor board ID JAE07081K07
R7000 CPU at 250Mhz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache
Last reset from power-on
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x32,
Board Hardware Version 3.34, Item Number 800-5171-02,
Board Revision C0, Serial Number JAE07081K07,
PLD/ISP Version 2.2, Manufacture Date 22-Feb-2003.
Processor 0x14, MAC Address 0x0BFDA254C
Backplane HW Revision 1.0, Flash Type 5V
2 FastEthernet/IEEE 802.3 interface(s)
25 Serial network interface(s)
120 terminal line(s)
4 Channelized E1/PRI port(s)
512K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
Thank you!
gatekeeper reuiqres an image with -x- in the filename. then in more recent IOS this may have changed. So depending on which IOS version you want to run, you have to pick a feature set that support gatekeeper, the one you currently have does not.
Please consider 2600 to configure for H.323 gatekeeper instead of as5350.
i have 2600 & 2800 chassis with me. could you please tell me the hardware configuration and the compatible IOS image name to enable gatekeeper functionality.
Thank you!
Dear Rasan,
Do yo solve your problem ?
I try to click link provided above, it expired
