LWAPP client counts snmp MIBS
Nov 22nd, 2007
I have been asked to put a cricket page with total number of wireless clients using the infrastructure for management to look at. Does anyone know which IOD provides information on the total clients count for WiSM type of controllers? Perhaps the name of the MIB would guide me in the right direction. I downloaded most of the LWAPP related MIBS from Cisco, but I haven't been able to find such a counter.
Thanks for any information.
Overall Rating: 4 (1 ratings)
Richard Atkin Fri, 11/23/2007 - 09:40
Sorry, not a clue. I'm sure there will be such a MIB as WCS does exactly that. So I guess either (a) Keep looking, or (B) Buy WCS ;o)
christopher.coc... Mon, 11/26/2007 - 06:22
Thought I would throw in what I have found...
I work with AP/WLC configuration using SNMP directly to wireless controllers -- and then use WCS for support personnel and map tracking. I write scripts that query statistics off each controller, then use PHP/Perl to display the results.
The AIRESPACE-WIRELESS-MIB is the best place to start. Don't know the OID at the moment, but the client info you are looking for is in the bsnMobileStationTable. It lists all the clients (actually looks like the info from the WLC clients page).
If you want more specific statistics (bytes in/out), you can also query the bsnMobileStationStatsTable and bsnMobileStationExtendedStatsTable.
For example, with NetSNMP installed somewhere (and you have the MIBs installed), you can use:
snmpwalk -OQs -v 2c -c snmprwstr -m AIRESPACE-WIRELESS-MIB mywlc bsnMobileStationTable
This command will dump the entire table to stdout. I've written a perl script (fairly straightforward and generic) to take this table and make it into a line-by-line showing of each client.
Hope this helps!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
