IPCC 3.1 consult
Answered Question
Nov 22nd, 2007
  • Bronze, 100 points or more
Hi folks, I have a CCM 3.3(4) and a IPCC 3.1, I need to upgrade the CCM 3.3(4) to CCM 3.3(5) or later version because I have IP PHONES 7911G that isn't is supported by CCM 3.3(4). My question is if IPCC 3.1 is compatible with CCM 3.3(5).
Thanks a lot by your suggestions.
Best Regards.
Correct Answer by Rob Huffman about 9 years 7 months ago
Hi David,
Yes, good call here! The 3.1(1) to 3.1(3) would not require new licening but the upgrade to 4.0 (4.0(5)) does. This may impact your decision for sure.
Hope this helps!
Rob
Overall Rating: 4 (1 ratings)
Rob Huffman Thu, 11/22/2007 - 18:35
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi David,
Yes, these are compatible versions (we have run 3.3(5) with IPCC 3.1(3)) This link has the "full" story :)
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/crscomtx.pdf
Hope this helps!
Rob
PS: Don't forget CCM 3.X Versions are End of Support August 2008.
david-lima Fri, 11/23/2007 - 05:26
Hi Rob.
Thanks for your information,
Just one more question.
How about if actually I am running IPCC version 3.1 (1) with a CCM 3.3.4, which runs Okay, and I have to upgrade my CCM to a version 3.3.5 or 4.1.3 (because the 3.3.4 version does not accept last IP Phones models like 7911 or 7906). This step obligates me to upgrade my IPCC to an IPCC version 3.1.(2) at least, for compability with the CCM 3.3.5, or to the IPCC version 4.0 upgrade, if my CCM is upgraded to a 4.1.3 version.
my question is related to the licences I have for the IPCC, I am worried if I upgrade the IPCC to a latest version, the licenses I have will need some upgrade or something else.
Thanks again for your help.
Best regards
David
Correct Answer
Rob Huffman Sat, 11/24/2007 - 12:31
  • Hall of Fame,
    Founding Member
Hi David,
Hope this helps!
Rob
david-lima Tue, 12/04/2007 - 04:52
Thanks a lot Rob for your helpful suggestions.
Best regards
David
