set auto is up, hardcode goes down, why?
Full story is, when we plug a device to a Giga port, no matter notebook or server, that switch port will work normally if config duplex and speed as auto. (Result is 100MB/Full)
But if we config as:
speed 1000
duplex full
The port will immediately down.
With same device plug to another port (within same module), hardcode as 1000/Full, working fine.
The diagnostic test on the module have no problem.
michelpe Fri, 11/23/2007 - 04:46
  • Cisco Employee,
Not sure why it's port dependant, but if you want
to fix speed/duplex you should do so on both sides.
Michel
glen.grant Sat, 11/24/2007 - 04:08
  • Purple, 4500 points or more
check to see if auto mdix is enabled on that port , if it is that will shut down the port using anything but auto as mdix will only work as auto , just something to check.
