Is cisco 3560 support VPN?
I'm new in networking.
I found that cisco router 28XX
has the VPN feature in the security option:
Security Solutions
Network Admission Control (NAC)
Voice & Video Enabled IPSec VPN (V3PN)
Optional Security Modules
IDS/IPS Network Modules (NM-CIDS portfolio)
VPN and Encryption Advanced Integration Modules (AIM-VPN portfolio)
Content Engine Network Modules (NM-CE portfolio)
Is the layer 3 switch "cisco 3560" support the same VPN feature as the router?
Wayne Wan
Overall Rating: 5 (2 ratings)
JORGE RODRIGUEZ Thu, 11/22/2007 - 20:23
Wayne, unfortunately no vpn features , you need an actual router, the 3560-3560-E L3 switches are not full blown routers, these have their limitations, for example there are three IOS feature sets for 3560s IP Base L2 forwarding, Base IPv6 services Basic routing , security IP Services Full EIGRP and OSPF, Multicast routing , PBR and Advanced IP services IPv6 routing, none of which supports vpn's.
You may download this file for specs on 3560 3560-Es
