Need info on switch modules..
Nov 22nd, 2007
Hi All,
I have some questions on switches in general.
Can I get help on the following modules on the switch.
1.What is a Backplane?
2.Why is a sup card needed?
3.why are MSFC AND PFC cards used?
4.what should I look for when I want to install 2 supcards on 6509 switch?
Thanks in Advance.
Overall Rating: 4 (1 ratings)
JORGE RODRIGUEZ Thu, 11/22/2007 - 21:31
In summary
Suppervisor EngineManages 6500 switch, modules installed , VLAN management etc.. usually runs CatOS code.
MSFC, MSFC2 Routing engine or router , a doughter card installed in Sup engine. Runs IOS code.
PFC or PFC2 Policy Feature Card - another doughter card Installed in Sup engine,
QoS functionality resides on the PFC and is a requirement for Layer 3 or Layer 4 QoS processing.
6500 Backplain Refers to 6500 Chassis BUS Fabric architecture
Ethernet Modules Ethernet cards installed in 6500 switch slots, 48 10/100/1000 Base-T
To install two sups in a single chassis is to provide L2/L3 redundancy failover, both need to be same model, same sup type , same IOS code for highavailability.
Here is all the information you need
Q&A on 6500 series
Pls rate any helpful posts !
