Link Drop after few minute.
Nov 22nd, 2007
we are facing a problem in main bandwidth link, bandwidth is terminated on a Cisco 3550 Switch, and then routed to 3660 Router, we have almost try every possible scenario, but facing still problem, e.g, changing fiber cable route, fiber modules, router (7206, 2621) but probem is still there,
This dropeg does not creat effect on Browsing, but VPN clients disconnected and VOIP connection disconnected because of this dropeg
You can see the attached file to analysis the drop in link.
Waiting for a solution...
bvsnarayana03 Thu, 11/22/2007 - 22:12
From the graph it looks like you are facing complete outage at frequent intervals. If this is for ISP link, then corrdinate with them for getting it rectified.
As far as voice & vpn is concerned, you may prefer to apply Qos but that wont be effective until u get the circuit rectified by provider.
mansoor_nawaz78 Thu, 11/22/2007 - 22:40
we have try the link with another service provider, but problem is still not rectifie.
jorg.ramakers Thu, 11/22/2007 - 23:54
Is the router has a lot of traffic to deal with. Type in the hidden command sh int switching. if you have a lot of runts, your route processor can't handle the traffic
Cheers
Jorg
