Mpls vpn routing problem!
v.matiakis
I have 2 mpls vpns. These 2 both receive routes from a route-target. Let's say that there is vpn_A and vpn_B. in show ip route vrf .. command both show a bgp route pointing to a router that has the subnet connected. But in vpn_A the show mpls forwarding-table vrf .. command does not show any labels or a next hop router :
Local Outgoing Prefix Bytes tag Outgoing Next Hop
tag tag or VC or Tunnel Id switched interface
None Recursive 192.168.199.0/24 0 .In vpn_B a label and a next hop router exist. Should i add a static route for the vrf pointing to the next hop?
21 Replies 21
Jon Marshall
You shouldn't need to. Could you describe your topology in a bit more detail ie. which routers are involved (CE,PE,P) and also provide configs for the relevant routers.
Jon
The topology goes like this :
PE1(vpn_A) - P - P - PE2(vpn_B). The 2 PE'S. the CE'S. In the routing table of PE1 there is a route to PE2. On the PE2 there is a route for PE1 vnp_A. Both have vlan interfaces configured for example on PE1 :
interface Vlan107
ip vrf forwarding vpn_A
ip address 192.168.1.240 255.255.255.0.
The vrf config on both PE'S :
ip vrf vpn_A
rd 1234:260
route-target export 1234:260
route-target export 1234:950
route-target import 1234:260
route-target import 1234:95
ip vrf Vpn_B
rd 1234:95
route-target import 1234:950
route-target import 1234:95.
hope this in enough
Can you provide
Full config of PE1 and PE2.
Jon
I am really sorry this is impossible, huge config and i am in a productive network.Can i send anything else?
No Problem, i understand. If possible could you provide the outputs of the following commands from both PE's
1) sh ip ro vrf VPN_A
sh ip ro vrf VPN_B
2) sh mpls forwarding-table
3) sh mpls forwarding-table vrf VPN_A
sh mpls forwarding-table vrf VPN_B
Jon
show ip route vrf vpn_A
C 192.168.1.0/24 is directly connected, Vlan107
B 192.168.199.0/24 [200/0] via Pe2's_loopback, 19:01:05
show mpls forwarding-table vrf vpn_A
822 Aggregate vrf:vpn_A 40096523
823 Untagged 192.168.10.0/24[V] \
20828455849 Vl107 192.168.1.83
824 Untagged 192.168.30.0/24[V] \
1103199 Vl107 192.168.1.4
show ip route vrf vpn_B
B 192.168.1.0/24 [200/0] via Pe1's_loopback, 1d05h
show mpls forwarding-table vrf vpn_B
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or VC or Tunnel Id Switched interface
593 Pop Label IPv4 VRF[V] 15550 aggregate/vpn_B
2981 No Label 192.168.199.0/24[V] \
83985816861 Vl110 P2_PUBLIC_ADDR...
I have another PE with same config and when i do show ip route vrf command for the vpn_B there a line saying "MPLS REQUIRED" which does not appear in the PE1.also they have a diff in the config :
address-family ipv4 vrf vpn_A
redistribute connected
redistribute static route-map SetPreference50
no auto-summary
no synchronization
exit-address-family
no synchronization
exit-address-family
No auto-summary does not matter here. It is required only when u are using RIP, EIGRP etc.
If it is showing "MPLS required".. cross varify you have enabled mpls ip @ global configuration and @ interface configuration. If u have not enabled it @ interface or global, u can still see the routes as routes go via MPBGP but u can not ping each other.
Vikas Sharma
mpls ip is enabled both globally and locally. In fact i have noticed that in PE1 there is no vrf vpn_B and an address family for vpn_B. How can i clear this bgp route in this specific vrf?
Vasileios, there is nothing wrong with your setup at all. Please see the explanation below.
1) show mpls forwarding vrf x.
this command gives you output of the nexthop and the label reuqired only of the routes it is originating itself, and not for the remote routes.
For eg: On Pex-CEx.
If the PEx has received 10.1.1.1 route from CEx , then only you will see the nexthop and local label for the prefix in show mpls forwarding vrf x. If a route for eg 20.1.1.1 was received from PEy then it wont show up in show mpls forwarding vrf x but will only show up in show ip route vrf x.
2) MPLS Required: on the contrary this means that to switch the packets to that nexthop MPLS is required. If you do a show ip route vrf x x.x.x.x then you will see MPLS required mentioned for each and every route in that vrf except for routes which which were originated locally form a directly connected CE.
Referring to the example above in point 1, the same 10.1.1.1 route wont need MPLS as its connected to local CEx so there wont be MPLS required for show ip route vrf x.
But for 20.1.1.1 there wont be MPLS forwarding entry but there would be a MPLS reuqired entry in show ip route, as to reach this prefix on a remote PE MPLS is required till the remote PE.
So what you are seeing is normal.
HTH-Cheers,
Swaroop
Goodmorning and thanx for the responses. The weird thing is that the vrf routing table has the right routes, other vrf on the same router having the exact destination works just fine. We have don the whole mpls vpn on the router from the beginning, but nothing changed? Could it be an interface problem?
As mentioned in my earlier post, all the outputs you put across were normal and nothing was wrong with them, if you see when it works then also the outputs would be similar.
You might have had a problem at the IGP-LSP level when you were troubleshooting the VRF labels :-)
HTH-Cheers,
Swaroop
The isis is the IGP and works fine with the other vpns. The problem remains for days now and nothing indicates a problem in the IGP. I have really tried everything and nothing worked. Similar vpn that take the also take the routes from the main vpn work just fine.
Just a small note: "show mpls forwarding" does only list the locally assigned labels other than "implicit null". Thus not every network will show up here, especially networks learned through BGP in a VRF do usually not have a locally assigned label and thus do not show up.
The command to look at is "show ip cef vrf ... detail" which will tell you, which label stack is implemented when sending a packet towards the specified destination network. In case you have multiple pathes to the BGP next hop you might see a "recursive" statement, i.e. you need another "show ip cef" for the BGP next hop to see the full label stack.
Hope this helps! Please rate all posts.
Regards, Martin
