Switches to Routers connection on CiscWorks
Nov 23rd, 2007
On Campus Manager, topology view, the routers are displayed disconnected from the switches, why don't i see the link between the switches and router?
Thank You for your time and assistance,
Genet .
frankzehrer Fri, 11/23/2007 - 00:47
  • Silver, 250 points or more
Hi Genet,
what Version of CM you are uning?
Do you have CDP enabled on the devices?
Best regards,
Frank
itssnsu07 Fri, 11/23/2007 - 00:54
Thank You very much, frank. I am using CM ver4 and yes have enabled cdp.
Thank You again!
Genet T.
frankzehrer Fri, 11/23/2007 - 00:57
Hi Genet,
what subversin? You need to be more specific.
4.0.0 or 4.0.3 or 4.0.9?
Frank
frankzehrer Fri, 11/23/2007 - 01:11
Hi Genet,
therefore i assume you are running LMS 2.5.1.
There were issues like that in the older CM Versions on the 2.5.x train and should now be fixed.
You should obtain the free Upgrade to LMS 2.6 and then upgrade to CM 4.0.9.
Best regards,
Frank
itssnsu07 Fri, 11/23/2007 - 03:47
Hi Frank,
True i am running LMS 2.5
I will upgrade both and check the outcome.
Thank You so much for your time and Help.
kind Regards,
Genet
