ASA 8.0 hangs on while URL filtering is on
Nov 23rd, 2007
ASA8.0 hangs while URL filtering is on. We use Websense for integration with ASA. ASA Randomly stops URL requests from Websense while user want to go internet. Does anybody experience this like problem ?
serkan Thu, 11/29/2007 - 23:22
Thank you for your reply. But this bug is still hidden to CCO users.
jasonsuplita Sat, 12/01/2007 - 19:41
Are you able to log into the Cisco bug toolkit? In case you don't have access to the toolkit, here is the output to the bug that hadbou was mentioning:
CSCsl42026 Bug Details
Headline ASDM: Hangs when filtering in log view
Product asdm
Feature OTHERS Components Duplicate of
Severity 3 Severity help Status Assigned Status help
First Found-in Version 6.0(2) First Fixed-in Version Version help
Release Notes
Symptom:
ASDM may freeze when filtering on an IP address in the log view. When this occurs, the only
recovery is to terminate the ASDM process under Task Manager and restart ASDM.
Conditions:
Monitoring -> Logging -> View
Filter on some IP, pause, clear, clear the filter, play, pause, clear
then go back to check configuration
ASDM freezes, after a few seconds you can interact with other programs
on the PC, but ASDM is still frozen
X.X.X.X
password/password
Java version: 1.6.0_03-b05
Workaround:
There is no known workaround for this specific issue.
