Cisco Ap1242 with Linksys Wet54g ethernet bridge
Nov 23rd, 2007
Hi to all!
Can i use any ascii key as wpa2-psk?
When i try to use some ascii keys the linksys bridge does not authenticate with the Ap. Reading the Ap log it says "authentication failed".
What could it be the problem? (they both have the same PSK (ascii)).
Why's that?
Is there any incompatibility with some ascii characters between this two devices?
e.g. 190oWh@.78#793mFj#,[email protected]
Thanks in advance
ivillegas Thu, 11/29/2007 - 08:55
AP allows only association of Workgroup Bridges as their client not the bridge itself. Check if you ahve configured the bridge in Workgroup bridge mode.
uosambela Mon, 01/07/2008 - 08:58
I think that is not a configuration problem. Without any security policy (wep, wpa) i can connect to the Ap.
Anyway, if i put a simple key (for example: 12345678) i can connecto to the ap. The problem is when i configure the psk with some ascii characters (for example: @#).
thanks for your help.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
