Use the system env temperature threshold yellow global configuration command on the switch stack or on a standalone switch to specify the difference between the yellow and red temperature thresholds and to configure the yellow threshold. Use the no form of this command to return to the default value.
system env temperature threshold yellow value
no system env temperature threshold yellow value
