EIGRP in GRE Tunnel and recursive routing
Nov 23rd, 2007
Hi All.
Scheme:
Remote branches connected to main site via Layer2 connection (primary) and Layer3 IP MPLS network connection (backup).
Primary connections are collected on one router while backup to another.
Task and problem:
I'm trying to setup EIGRP for this scheme
For some unknown reasons Tun33 goes down on the main site.
%TUN-5-RECURDOWN: Tunnel33 temporarily disabled due to recursive routing
I've tried to completely disable all possibilities for announcing Tun IP's
BRANCH-33 configuration
interface Tunnel33
description << IP MPLS >>
ip address 172.22.1.26 255.255.255.252
tunnel source 172.26.0.26
tunnel destination 192.168.255.2
end
ip route 192.168.255.2 255.255.255.255 172.26.0.25
! Static route to tun33 dest
router eigrp 300
redistribute connected
network 172.22.1.24 0.0.0.3
distribute-list prefix REDISTR-EIGRP out
no auto-summary
neighbor 172.22.1.25 Tunnel33
ip prefix-list REDISTR-EIGRP
seq 1 permit 10.0.176.0/27
seq 2 permit 10.129.176.0/27
seq 3 deny 172.22.1.24/30
MAIN SITE CONFIGURATION
interface Tunnel33
ip address 172.22.1.25 255.255.255.252
tunnel source 192.168.255.2
tunnel destination 172.26.0.26
end
ip route 172.26.0.0 255.255.255.0 192.168.255.1 tag 333 name IP_MPLS
router eigrp 300
distribute-list prefix DENY-TUN-REDISR-EIGRP out
no auto-summary
neighbor 172.22.1.26 Tunnel33
ip prefix-list DENY-TUN-REDISR-EIGRP seq 1 deny 172.22.1.24/30
ip prefix-list DENY-TUN-REDISR-EIGRP seq 2 deny 172.26.0.24/30
ip prefix-list DENY-TUN-REDISR-EIGRP seq 3 deny 192.168.255.0/30
Overall Rating: 4 (1 ratings)
jarredtaylor Fri, 11/23/2007 - 04:39
Maxim,
I think your main site router is learning a more specific route to the tunnel destination (172.26.0.26) via EIGRP over the tunnel. I assume the network 172.26.0.24/30 is directly connected to the branch router. Rather than denying the advertisement of that prefix from the main site, you should instead be denying it from the branch. Try adding 'seq 4 deny 172.26.0.24/30' to the REDISTR-EIGRP prefix list on the branch router.
Jarred
MaximBudyonny Fri, 11/23/2007 - 05:01
Thank you Jarred.
You reply was very helpful.
But the root of the issue was just a typo in cisco config. :-(
Instead of "distribute-list prefix REDISTR-EIGRP out" I typed "distribute-list REDISTR-EIGRP out" while in the forum post I've wrote correct command.
Copy-Paste is really great technic! :-)
deb ip eigrp 300 helps me to find this error.
I've seen that for some reasons branch router advertises some networks while it must not be.
Problem is solved.
I'm greatly appreciate to you. Your propose is very interesting.
