Catalyst switch 2950 XL LRE
Nov 23rd, 2007
Hi dear,
I have some Catalyst switch 2950 XL LRE
, but right now cisco discontinued to product that switch, any similiar cisco switch like that or do you know another switch type for replacement Catalyst switch 2950 XL LRE?
Regards,Edgar
Overall Rating: 3 (1 ratings)
edgar_pascal Fri, 11/23/2007 - 05:25
Hi Michael,
I see Catalyst 2960 doesn't support LRE
(Long Reach Ethernet) am i right ?
Do you know another type or anoher brand?
Edgar
glen.grant Fri, 11/23/2007 - 09:15
  • Purple, 4500 points or more
Nope they got rid of LRE basically DSL after the 2950 series . Don't know of anyone else that has something like that but it may be out there , i guess google is your best bet on this one .
edgar_pascal Fri, 11/23/2007 - 16:31
May be Cisco Administrator
can helpme to find very similiar product with cisco LRE ?
Thanks to Glen and Micahel, for your respon.
Edgar.
JORGE RODRIGUEZ Fri, 11/23/2007 - 17:52
  • Green, 3000 points or more
Edgar, the 2960 replaces this model, please check Table 2 link bellow for upgrade path information.
http://www.cisco.com/en/US/products/hw/switches/ps628/prod_eol_notice0900aecd806ea1da.html
2960 Product page includes Product Literature, Q&A etc..
http://www.cisco.com/en/US/products/ps6406/index.html
Pls rate any helpful posts !
Jorge
mpc_netsupport Sat, 11/24/2007 - 01:39
Cisco Catalyst 2950 LRE has been discontinued, but you can contact cisco to buy the refurbished.
edgar_pascal Sat, 11/24/2007 - 04:50
I already have 7 cisco catalyst switches 2950 XL LRE and our customer happy to used it, and we need more and more.
Can you help me to find the refurbished LRE switch?
Edgar
JORGE RODRIGUEZ Sat, 11/24/2007 - 05:28
Edgar, you can try http://www.dexon.com/ , they do carry refurbish 2950 switches , you should be able to find it ther or ask them for the LREs and they will find it.. I buy from them, very reliable with non-smartnet warranty.
Jorge
