Login to Cisco Unified CM User Options at Cisco Callmanager 6.0
mbroger
Hi Guys
we are running at the moment the CM 4.1.3 and now i am testing the new CM 6.0 because we are planing to Upgrade it.
At the Old CM the users can acces the webpage
https://hostname/ccmuser/logon.asp
to edit theire speed diles.
At the new One CM6 i found the same web page at
https://hostname/ccmuser/showHome.do
But i cant log in. I have added some users at the User Managment -> End User but this dosnt work.
What i make wrong ? or where is the solution.
Greeds Feichti
Chris Deren
You need to associate the users with "End User" user group. As far as the url you can only enter https://hostname/ccmuser
HTH,
Chris
thanks a lot it works :)
Feichti
