When should progress_ind be used?
Nov 23rd, 2007
Should progress_ind always be configured in dial-peers with h.323 gateways? If not, when should progress_ind {setup | connect | progress | alert} be used?
allan.thomas Fri, 11/23/2007 - 05:59
There are certain situation issues which can arise when interoperating signaling capabilities between the gateway and Telco, one common problem is no Ringback tone.
Configuring progress_ind should only be configured when necessary. Please review the following link, it describes in detail issues such as the no ringback tone on PSTN calls, and how to troubleshoot and resolve it using the progress_ind command.
Pls rate this post if you find it helpful.
