Dual RP-TNC in 1200 Radios
Answered Question
Nov 23rd, 2007
There somethig that i would like to understand..
what is the purpouse of a dual antenas in a 1240G.
I understand the diversity feature, but i dont understand the purpouse of dual antenas
in a 1240G radio.
Are two internal radios (one each antena) or is only one radio with two antenas...
how it work?
Correct Answer by Rob Huffman about 9 years 5 months ago
Hi Rafael,
Hope all is well with you :)
The 1240G has only one b/g radio and will have one set of Dual RP-TNC connectors in case you want to hook up two Antennas in Diversity Mode (as you nicely noted!) In many cases you will just use one Antenna connected to the Primary RP-TNC side.
The 1240A/B/G has only one b/g radio and one A radio and will have two sets of Dual RP-TNC connectors. One dual set for each radio in case you want to hook up two Antennas in Diversity Mode. In many cases you will just use one Antenna connected to the Primary RP-TNC side for b/g and one Antenna connected to the Primary RP-TNC side for A.
For the 1240G
Dual RP-TNC antenna connectors for 2.4-GHz radios
Antenna connectors support a variety of Cisco 2.4-GHz antennas, providing range and coverage versatility.
http://www.cisco.com/en/US/products/ps6521/products_data_sheet0900aecd80635208.html
For the 1240A/B/G
Dual RP-TNC Antenna Connectors for Both 2.4-GHz and 5-GHz Radios
Antenna connectors support a variety of Cisco 2.4-GHz and 5-GHz antennas, providing range and coverage versatility.
http://www.cisco.com/en/US/products/ps6521/products_data_sheet0900aecd8031c844.html
Cisco Aironet 2.4 GHz and 5 GHz Antennas and Accessories
http://www.cisco.com/en/US/products/ps6521/products_data_sheet09186a008022b11b.html
Hope this helps! And makes some sense :)
Rob
Overall Rating: 4.5 (2 ratings)
scottmac Fri, 11/23/2007 - 07:11
  • Green, 3000 points or more
It is one radio (802.11g) with two antennas, only one of them is active at any given time (antenna A is Tx/Rx OR antenna B is Tx/Rx). Thre is only one path to the radio, and only one antenna can occupy that path at a time.
Then there may be also an 802.11a radio with either an integrated "padddle" antenna or another version of that radio has two antenna jacks.
Both radios have two antennas to enable Diversity; basically two views of the SAME AREA to reduce the chances of Nulls and minimize multipath effects.
Good Luck
Scott
Correct Answer
Rob Huffman Fri, 11/23/2007 - 07:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rafael,
For the 1240G
For the 1240A/B/G
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
