11-23-2007 06:14 AM - edited 03-21-2019 12:53 AM
Hi all.
I tried to backup the configuration of a 500 express switch, just in case of a failure and replacement event.
I used network assistant 5.2, but the backup always fails. I suppose it is not a firewall issue, as I put my PC on the switch management network and I see tftp port open on the "netstat". Any hint?
Best regards.
11-29-2007 09:15 AM
You can refer to this bug for more information on config archive with 500 express switch:
CSCsk16910
01-17-2008 10:54 AM
I just pulled the flash card out of the UC500, with the router off, and used a flash card reader on my PC.
A good article is here at uc500.com
02-06-2008 02:25 PM
Do you still see this problem? If yes, could you please attach the log? I might be able to help.
thanks
02-07-2008 12:41 AM
No, thanks.
I opened a TAC and we found it was something related to the java machine version on the laptop.
