show snmp mib
Answered Question
Nov 23rd, 2007
Is it the correct behavior that "show snmp mib | include ifInErrors" doesn't return anything? I do see a bunch of "ifEntry.#" and
ifMIB.1.5
ifMIB.1.6
with "show snmp mib | include if"
Correct Answer by Joe Clarke about 9 years 3 months ago
Yeah. The way IOS builds the internal MIB tree doesn't mean that each object will be translated to it's actual object name. Many times, the object will be referred to be its table entry, then index in that table, or by the MIB, then the table, then the object.
You can use my SNMP translate tool at http://jaguar.ir.miami.edu/~marcus/snmptrans.html to do bulk file translations. This should handle most of the objects show snmp mib returns.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 11/23/2007 - 11:23
