Way to block specific syslog message
Nov 23rd, 2007
Is there a way or will there be a solution on how to block a specific messages before sending it to a syslog server. So far, they can be blocked by severity groups.
For example, i would like to block the the following level 3 message:
%CCH323-3-CALL_SETUP_FAILED: cch323_process_alternate_call_setup_result: call setup failed
Level 3 are error messages, so i wouldn't dare blocking them.
The idea is to use the front-end for blocking, rather than the syslog itself.
rclousto Fri, 11/23/2007 - 07:51
Hi, this doesn't look at all related to SNA networking. Please post this in the correct NetPro forum (Voice over IP?) so that the experts in that technology will see your question.
