CIPC & Microsoft Firewall Client
Nov 23rd, 2007
I have a cu trying to run latest version of CIPC (same problem confirmed with previous versions as well), during testing we experienced only incoming (one-way) voice. After troubleshooting and isolating the issue it shows that once Microsoft Firewall (ISA) Client is installed, that breaks the CIPC. Just disabling FW-client service does not help.
Has anyone seen this issue, and if so, is there a solution? My knowledge of the ISA-client is very limited. :)
Best regards,
/M
gogasca Sat, 11/24/2007 - 01:08
  • Green, 3000 points or more
You may check with MS support why they are blocking RTP traffic.
to confirm just gather sniffer capture to confirm RTP stream arrives to the NIC
mlundbom1 Sat, 11/24/2007 - 03:40
Once the F/W-client is installed, the CIPC outbound counter from call statistics does not increment at all, so no outbound RTP-stream reach the NIC at all.
I do believe MS support is the next step, but I'm still curious if anyone else has seen this issue.
