Access Web Server from Internet to inside interface
Answered Question
Nov 23rd, 2007
I have a problem with my Web Server on LAN (Inside interface). I am not able to reach it from Internet. I have tried many different Access Rules, but can't get it run. When I do a Packet Trace with ASDM, it say an access-list error (see in attachments).
Thanks for your help.
Correct Answer by husycisco about 9 years 6 months ago
In 192.168.0.102 server, enter www.whatismyip.com and check if your global ip is in 217.128.122.x network. Did you request more than 1 IPs from your ISP or this is your only IP?
If this is your only IP, add the following
no static (inside,outside) tcp 217.128.122.84 www intranet www netmask 255.255.255.255 dns
no access-list outside_access_in extended permit tcp any host 217.128.122.84 eq www
static (inside,outside) tcp interface www intranet www netmask 255.255.255.255
access-list outside_access_in extended permit tcp any interface outside eq www
now try to browse the IP, which you see in whatsmyip, from internet in somewhere
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Fri, 11/23/2007 - 18:53
  • Green, 3000 points or more
Hi, lets take this step by step looking at your config there are couple of things but 1st where is the defaul route, I do not see a default route in asa.
can you issue at command line show route | inc 0.0.0.0 and post output.
Jorge
mhennebicq Tue, 11/27/2007 - 10:36
I used "Obtain default route using PPPoE" with Startup Wizard... Is it wrong ?
kunal.shandil Sat, 11/24/2007 - 04:47
For the access from outside 2 things are required
1) Static Translations
2) ACL
The Screen shot is showing the Packet is getting dropped due the implicit deny policy and its not matching ur configured ACL.
plz corrct me if i am wrong
K
timkaye@empired Mon, 11/26/2007 - 20:08
You are not wrong.
The ACL is built wrong (its defining a source port of www) to host 217.128.122.84.
access-list outside_access_in extended permit tcp any eq www host 217.128.122.84
It should be
Please rate helpful posts :)
Tim
mhennebicq Tue, 11/27/2007 - 10:28
Hi !
Tks a lot for your help but I have the same error :-(
710003 81.253.x.y 217.128.122.84 TCP access denied by ACL from 81.253.x.y/51574 to outside:217.128.122.84/80
Is it can be a license limit ? Or due to the internal http server of ASA ?
Correct Answer
husycisco Wed, 11/28/2007 - 04:55
  • Gold, 750 points or more
