AP and DHCP problem
Nov 23rd, 2007
I have a router with 2 subinterfaces.
interface GigabitEthernet0/0.1
encapsulation dot1Q 20 native
ip address 130.130.130.1 255.255.255.0
ip helper-address 192.168.1.5
interface GigabitEthernet0/0.99
encapsulation dot1Q 99
ip address 120.120.120.43 255.255.255.248
I have a 3750 level 2 with this vlans.
interface Vlan99
ip address 120.120.120.41 255.255.255.248
interface Vlan20
ip address 130.130.130.10 255.255.255.0
I have the AP is connected to a port in the 3750
interface FastEthernet1/0/47
switchport trunk native vlan 99
switchport trunk allowed vlan 20,99
switchport mode trunk
Users connected to the 3750 ports vlan 20 can get IP from the range 130.xx
I want users connected to the access point to have IP's from range vlan20 (130.xx) (the same that the users connected to the 3750)
HOw can i do it?
glen.grant Sat, 11/24/2007 - 06:16
Instead of using the trunk parameters on the fastethernet interface inself you have to use subinterfaces on the wap also . You will have to use subinterfaces on your bridge interfaces also.
