thestagman Mon, 11/26/2007 - 04:49
Hi thanks
for the reply, here is one end of my VPN Site to Site config : -
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key XXXXXXXX. address X.X.X.X (Docklands Address)
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map DCK_FTWR 1 ipsec-isakmp
description Tunnel to X.X.X.X (Docklands Address)
set peer X.X.X.X (Docklands Address)
set transform-set ESP-3DES-SHA
match address 100
access-list 100 remark DCK_FTWR Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip any any
Interface Commands
Int G0/1
crypto map DCK_FTWR
crypto ipsec df-bit clear
I'm not sure about the packet size I will have to investigate. Lets assume they are small so worst case ..
Cheers
bauer.juergen Mon, 11/26/2007 - 06:10
56 byte for esp
20 byte extra for the outer ip header
smallest packet on ethernet(?): 64 byte
so your overhead could be more than 100%
of course you will have big packets on your net as well - for user data, file transfers etc.
