licensed host limit of 10 exceeded!?!
Nov 23rd, 2007
ASA5505 8.0(2) with standard license.
1 server
1 SSL VPN AnyConnect client
1 outside interface
Since my SSL VPN client sets the default route I thought I try to reach internet via my ASA.
"Deny traffic for protocol 6 src outside:10.200.0.10/2489 dst outside:87.248.113.14/80, licensed host limit of 10 exceeded"
10.200.0.10 being my SSL VPN client.
I understand how (outside vpn) -> (outside) NAT might be a problem but why is the license check being triggered?
Any ideas on how to get SSL VPN NAT'ed to outside?
TIA
Overall Rating: 4 (1 ratings)
JORGE RODRIGUEZ Fri, 11/23/2007 - 15:44
  • Green, 3000 points or more
You would need at least to upgrade your license to brake the 10 users limitation with ASA5505-50-BUN-K9. Outbound vpn/ssl is within the 10 user license limitation How many concurrent users/connections do you have?
Reref to this link for detail information. http://www.cisco.com/en/US/products/ps6120/prod_brochure0900aecd80402e36.html
Pls rate any helpful posts !
Jorge
Jason Gervia Mon, 12/03/2007 - 14:18
  • Cisco Employee,
Do a 'show ver' and see what your webvpn peers license is.
If you do a 'show vpn-sessiondb summary' you can see how many sessions are currently in use for sslvpn and whether that exceeds the webvpn peers line in your 'show ver'
--Jason
etxsthl100761 Tue, 12/04/2007 - 03:42
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 3, DMZ Restricted
Inside Hosts : 10
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
VPN Peers : 10
WebVPN Peers : 2
Dual ISPs : Disabled
VLAN Trunk Ports : 0
Advanced Endpoint Assessment : Disabled
This platform has a Base license.
Active Session Summary
Sessions:
Active : Cumulative : Peak Concurrent
SSL VPN : 1 : 22 : 2
Clientless only : 0 : 10 : 2
With client : 1 : 12 : 1
Email Proxy : 0 : 0 : 0
IPsec LAN-to-LAN : 0 : 0 : 0
IPsec Remote Access : 0 : 0 : 0
Totals : 1 : 22
License Information:
IPsec : 10 Configured : 10 Active : 0 Load : 0%
SSL VPN : 2 Configured : 2 Active : 1 Load : 50%
Total : 12 Configured : 12 Active : 1 Load : 8%
IPsec : 0 : 0 : 0
Totals : 1 : 22
Tunnels:
Clientless : 1 : 22 : 2
SSL-Tunnel : 1 : 14 : 1
DTLS-Tunnel : 0 : 2 : 1
Totals : 2 : 38
Active NAC Sessions:
No NAC sessions to display
Active VLAN Mapping Sessions:
No VLAN Mapping sessions to display
Only me, myself and I on this box so the license should be sufficient.
I get this rejection when I try to reach an IP beyond the default gw of my ASA from my AnyConnect client.
However if I try to reach something on the outside subnet it will send on the outside interface but without NAT'ing the source address( see attached capture)
Jason Gervia Mon, 12/10/2007 - 11:34
  • Cisco Employee,
The problem is that you have a restricted license that says only 10 users (read, 10 IP addresses with packets going to/from them at a time on the highest security level interface). It's not a VPN license issue - you'll have to get a new license if you want to reach more than 10 machines on the inside of your network.
