Dial-peer question
Nov 23rd, 2007
Hi everyone,
I'm having trouble trying to route calls through an IP trunk for some reason.
I've got the following two dial-peers:
dial-peer voice 5 pots
description Primary Outgoing Line
preference 1
destination-pattern 1T
port 0/1/1
forward-digits all
dial-peer voice 20 voip
description VoIP Trunk
destination-pattern 9[12]...
session target ipv4:172.30.0.10
no vad
The problem is that when I dial 91, the line goes out the voice port rather than the voip trunk!
As seen, there are two needs:
1) when dialing 1xxxx, it must go out the voice port
2) when dialing 91xxxx, it must go out the voip trunk.
Any suggestions as to how I can resolve this ?
Many thanks.
allan.thomas Fri, 11/23/2007 - 14:08
Can you possibly post the output of 'debug voice ccapi inout' when you dial 91..., this will determine how the digits are being matched.
Incidentally, on your voip DP you have only specified 3 digits after the explicit match 9[12]... Should this be four as inidcated in your needs, or did you mean 9xxxx?
Can you run 'show dialplan number 91234' and 'show dialplan 1.........#' capture and post the output.
Allan.
