Pix 501 PDM "No Data Available Yet."
Nov 23rd, 2007
I have a Pix501 running 6.3(5) software and PDM 3.0(4). I am using the graphing function of the PDM interface to graph interface bit rates. When I select a new history range, it seems that the data collection only begins when I select that range. I can't see any history unless I keep the graph window open. I could swear that it was stored last time I used this function so that you could log into PDM and see the last 12 hours for example. Maybe I am wrong. Is this not the case? Is there a function to enable the data to be collected while not actively graphing?
Thanks!
tstanik Thu, 11/29/2007 - 12:15
The graph history can only be seen for the time the graph window is open, once the window is closed the data is removed so you cannot see the history for the earlier time range.
