Problem Authentication with AP 1130AG
Nov 23rd, 2007
I have a problem with my access point model is 1130AG, it works fine , im using WEP encrypt, but just only 2 clients can connect to it, if i want to connect a 3rd client either laptop or pc the client sends a message Connectivity Null, but if disconnect or disabled any of the connected clients, the 3rd that i was trying connect, its connect inmediately. i dont know why just 2 clients can connect only to the access point, any help, i already attached the configuration, with no pass and WEP passwords. Pls Need Help with this
Richard Atkin Sat, 11/24/2007 - 00:03
  • Silver, 250 points or more
There's nothing in your config to suggest any limit on the number of client associations, however there are a number of bad practises on there that you may want to clean up in general.
Username = Cisco
Client VLAN = AP Mgmt VLAN
Using Static WEP = Very Bad
Still got all of the low-speed data-rates enabled
AP is on a massive broadcast domain, so performance is likely to be / get very bad
int dot11 0 channel not set
int dot11 0 power not set
int dot11 1 config is all over the place
The error message you posted suggests the client is opting to leave the AP, as opposed to the AP kicking it. What is the physical proximity of the AP & Laptops? Also, please please please make sure you've got the very latest drivers on your clients.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
