wan interface card configuration problem
Nov 23rd, 2007
hi,
we are using 2821 router with 1 NM-2CE1T1-PRI in slot 1 and 1 VWIC-2MFT-E1 card in HWIC 0 slot.the problem is that router is not taking the card type e1 0/card type e1 2 command.i have to configure 1 2MB link with unframed command on VWIC-2MFT-E1 card.router is taking card type e1 1 command on NM-2CE1T1-PRI(slot 0).pls suggest us what to do.
jarredtaylor Sat, 11/24/2007 - 06:36
Parba,
I believe on the VWIC cards you do not have to specify card type. Instead you configure the 'controllers' first. Afterwards the physical interfaces will show up in the config:
controller e1 0/0
interface s0/0:x
HTH,
Jarred
paolo bevilacqua Sat, 11/24/2007 - 12:48
  • Hall of Fame,
    Founding Member
VWIC-2MFT-E1 does no support unframed operation.
For that, you will need VWIC-xMFT-G703 or VWIC2-xMFT-G703.
