ROUTING
Nov 24th, 2007
I have purchase a new cisco 2821 router
configured with public address on outside interface with one subnet ip and configured inside interface with another subnet ip in turn connected to switch suppose i ping the isp gateway i am getting request time out i have configured default route, dns server,interface but i am able to ping to outside interface but not to isp gateway is there any access-list i have to specify in order to get access out of exit interface to internet
JORGE RODRIGUEZ Sat, 11/24/2007 - 05:32
  • Green, 3000 points or more
Prakash, it is probably your NAT and/or access list, can you post configuration, strip out publig IP info.. can you discribe your topology physical connections.
Rgds
Jorge
prakashkamte Mon, 11/26/2007 - 23:46
YES Both the interface are assigned two public interface from different the exit interface a.b.c.d and inside int is assigned e.f.g.h to which a host is connected i am able to ping from the host up till a.b.c.d but not to ping public dns there is no access list and and is not nated
vanguardro Mon, 11/26/2007 - 10:46
hello,
i suppose you use ip addresses from public ip address space, and because of this you don't need NAT.
can you do one traceroute from internet to you assigned ip addresses ?
vanguardro
