CCM5.1 integration with third party call manager
Nov 24th, 2007
Is it possible to integrate CCM5.1 with any other third party call manager?
if yes then Licenses are required for that?
Overall Rating: 5 (1 ratings)
Chris Deren Sat, 11/24/2007 - 07:19
You can integrate Cisco CallManager with another Cisco CallManager via intecluster trunk or other third part TDM PBX via a voice gateway. You can also integrate with 3rd party voip PBX via a voip protocol (i.e. SIP, H.323).
There is no additional licensing required.
desaitejas Mon, 11/26/2007 - 23:33
Thank You.
May i know the steps to configure intercluster trunk for Third party callmanager interface.
What configuration we have to do in CCM5.1
Chris Deren Sun, 12/02/2007 - 12:32
In CCM go to device-->Trunk
Select Intercluster trunk (non-GK controlled)
Name the trunk, complete all necessary fields, i.e. device pool, css, etc
under Remote CCM Information enter up to 3 IP addresses of the remote cluster servers.
Create a route group/route list/route patterns pointing to this trunks just like you create them for PSTN accesss.
Perform this on both sides if you want to allow calls back and forth between 2 clusters.
