11-24-2007 07:29 AM - edited 03-15-2019 07:24 AM
Hi everyone and really hope for your advices)
I have the following configuration:
GW(1760)---2620--(FrameRelay)--7304--|PIX|--6509--(local voice stuff)
11-24-2007 01:53 PM
11-24-2007 02:50 PM
Sorry, was diverted and then had forgotten about post on forum.So to the problem:
GW(1760)---2620--(FrameRelay)--7304--3640--|PIX|--6509--(local voice stuff).
As voice stuff i have as5350,CM and phones.
1760 & 2620 are situated in the remote offices and 1760 has FXS ports. The problem is that I can't make a call from this office.
we had several similar remote offices with 1760 and from this device command "csim start *my number* is working".The output of sh call hi vo br and sh call hi vo last 1 on working 1760 is:
1260 : 308242970ms.77 +-1 +21230 pid:100 Originate 3733
dur 00:00:00 tx:0/0 rx:1004/20080 0 ()
IP 172.18.0.3:16800 rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8
and
RemoteIPAddress=172.17.21.2
RemoteUDPPort=16800
RemoteSignallingIPAddress=172.17.21.2
RemoteSignallingPort=1720
RemoteMediaIPAddress=172.18.0.3
RemoteMediaPort=16800
while the same commands on the not working 1760 is:
0 : 79 74616091hs.79 +-1 +2002 pid:100 Originate 3733
dur 00:00:00 tx:0/0 rx:0/0 0 ()
IP 0.0.0.0:0 rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 pre-ietf
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
and
RemoteIPAddress=172.17.21.3
RemoteUDPPort=0
RemoteSignallingIPAddress=172.17.21.3
RemoteMediaIPAddress=0.0.0.0
RemoteMediaPort=0
*172.17.21.3 - it's CM
172.18.0.3 - it's AS (which is actually calling to *my number*)
11-24-2007 02:59 PM
also here is the debug of h225 asn1 and h225 events on non-working 1760:
Nov 25 00:31:37.630 EET: Changing to new event: CONNECT
h323chan_chn_connect: connecting to 172.17.21.2:1720
Nov 25 00:31:37.630 EET: h323chan_gw_conn: Created socket fd=3
Nov 25 00:31:37.630 EET: h323chan_gw_conn: connect in progress on fd=3h323chan_chn_connect: using fd=3, owner_data(ccb) 0x84315674
changing from NONE state to CONNECTING state
Nov 25 00:31:37.674 EET: h323chan_chn_process_read_socket: fd=3 of type CONNECT_PENDING has data
Nov 25 00:31:37.674 EET: Changing to new event: CONNECTED
changing from CONNECTING state to CONNECTED state
Nov 25 00:31:37.678 EET: compose_TunnelledSignallingMessage_ciscoNo tunnelled content.
Nov 25 00:31:37.678 EET: H225.0 OUTGOING PDU ::=
value H323_UserInformation ::=
h323-uu-pdu
h323-message-body setup :
protocolIdentifier { 0 0 8 2250 0 4 }
sourceAddress
h323-ID : {"luck"}
sourceInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
}, h323 :
supportedPrefixes
mc FALSE
undefinedNode FALSE
activeMC FALSE
conferenceID '00000000000000000000000000000000'H
conferenceGoal create : NULL
callType pointToPoint : NULL
sourceCallSignalAddress ipAddress :
ip 'C0A8C710'H
port 11989
callIdentifier
guid '00000000000000000000000000000000'H
fastStart
'00...100'H,
'400...C710...'H,
'00...100'H,
'400...8C7...'H
mediaWaitForConnect FALSE
canOverlapSend FALSE
multipleCalls TRUE
maintainConnection TRUE
symmetricOperationRequired NULL
h245Tunneling TRUE
Nov 25 00:31:37.702 EET: H225.0 OUTGOING ENCODE BUFFER::= 20...00180
Nov 25 00:31:37.706 EET:
Hex representation of the SETUP TPKT to send.: 080...180
h225SetupRequest: Q.931 SETUP sent from fd=3
Nov 25 00:31:37.710 EET: h323chan_chn_process_read_socket: fd=3 of type CONNECTED has data
Nov 25 00:31:37.710 EET: h323chan_recvdata: No Data on fd=3
PROCESS_READ: FAILED/NOT COMPLETE,rc 10, fd=3
ter
Nov 25 00:31:52.688 EET: compose_TunnelledSignallingMessage_ciscoNo tunnelled content.
Nov 25 00:31:52.688 EET: H225.0 OUTGOING PDU ::=
h323-uu-pdu
h323-message-body releaseComplete :
callIdentifier
h245Tunneling TRUE
Nov 25 00:31:52.692 EET: H225.0 OUTGOING ENCODE BUFFER::= 258...180
Hex representation of the RELEASE COMPLETE TPKT to send.: 080...0180
h225TerminateRequest: Q.931 RELEASE COMPLETE sent from fd=3. Call state changed to [Null].
Nov 25 00:31:52.696 EET: h323chan_close: TCP connection from fd=3 closed
What i've checked:
1 access-lists
2 NAT rules
I'm not sure in FrameRelay
Ss it a problem with the udp ports range 16384-32768? (signaling is OK)
sorry for a such chaotic post(writing at night) but will provide any details to help solving this problem
