Configures SBC yahoo DSL Dyname IP with 1811 Router
Answered Question
Nov 24th, 2007
I would like to setup Cisco 1811 Router with SBC Yahoo ADSL Modem (Siemens Speed stream 4100). DSL Modem is in bridge mode.
DSL modem get's a DHCP address from ISP and my LAN will also be configured as DHCP. Can i get a sample config i can use.
Osman
Correct Answer by Collin Clark about 9 years 8 months ago
Here's mine-
interface FastEthernet0/1
description DSL WAN Interface
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface Dialer1
description DSL WAN Dialer$FW_OUTSIDE$
ip address negotiated
no ip unreachables
ip nat outside
ip virtual-reassembly
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username [email protected] password 0 SeCrEt
dialer-list 1 protocol ip permit
ip dhcp pool dhcp-pool
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 206.141.192.60 65.43.19.26
lease 0 2
HTH and please rate.
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Mon, 11/26/2007 - 06:52
  • Purple, 4500 points or more
Here's mine-
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
duplex auto
speed auto
pppoe enable
interface Dialer1
no ip unreachables
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
import all
lease 0 2
osmansmalik Thu, 02/14/2008 - 19:46
Thanks for the post. The config worked like a champ.
Osman
Vikrant Ambhore Wed, 12/01/2010 - 23:02
Hello osmansmalik ,
I have same Setup as per you My setup is ISP------>modem ----> Cisco 1861 Router -----> Switch, I setup Cisco Interface as per your comment,  I want  to use dialer int of Cisco 1861 for getting IP from Modem ?  but I'm not sure if this modem can work as bridge just to translate packets to PPP from Cisco if this modem can work as bidge instead of router..
Can you suggest me  which protocol should be use on Modem ?
I know you said Bridge, but which I saw lot's of option there, I know this is sily question but I'm not familier, I hope you will help me
I hve below option in Modem
1: Dynamic IP Address
     1483 Bridge IP LLC
     1483 Bridge IP VC-MUX
     1483 Routed IP LLC(Poa)
     1483 Routed IP VC-MUX
2:   Static IP address
      1483 Bridge IP LLC
3:- PPPOe/PPPoA
     PPPoe IP LLC
     PPPoe Bridge IP VC-MUX
     PPPoa IP LLC
     PPPoa Bridge IP VC-MUX
4:- Bridge Mode
     1483 Bridge IP LLC
Vikrant
