Rate limiting on a Catalyst 5509 switch?
Nov 24th, 2007
Anyone know if this is possible, and if so, have any sample configurations to do it? I've been digging around Google and not coming up with a whole lot, and considering the switch is on End-of-life status, Cisco isn't supporting it either.
Edit: We're looking to set it up on a per-port basis.
Thanks!
-Glen
JORGE RODRIGUEZ Sat, 11/24/2007 - 23:22
  • Green, 3000 points or more
Glen, this is discuntinue product, you will have to do a little better, most of newer catalyst switches can do per port rate limiting , Qos etc.. , go to product link bellow and pick product look in data sheets and software feature information , it will indicate its capability in this technology.
For example I see these support rate limiting Catalyst 2960 LAN-base, 3560, 3560-E, 3750 etc..
For details refer to data sheets and/or software features ( Granular rate limiting)
http://www.cisco.com/en/US/products/hw/switches/index.html
Jorge
glen.underwood Mon, 11/26/2007 - 07:06
Jorge,
Thank you for the response, but just so I am 100% clear and can report the correct information to my boss....are you saying the 5509 is not capable of rate limiting on a per port basis?
Thanks!
-Glen
