dot1x authentication failed
Nov 24th, 2007
I have a 3550 switch with IOS 12.2.I have configured a single port fa/26 to authenticate via my radius server .for my switch when i give a test it works fine.
'osi_switch#test aaa group radius server deepa 01deepa01 legacy
Attempting authentication test to server-group radius using radius
User was successfully authenticated.'
But my system is not getting authenticated using the same login.below is my switch configuration
On the pc i have enabled md5 authentication on lan connection properties.
Any help will be highly appreciated.
amritpatek Thu, 11/29/2007 - 14:41
If the switch passes the authentication test this means that config in switch is fine. Try using a different PC on the same interface and check if this work fine.
