How to configure Pix 515e vpn to Symantec vpn
Answered Question
Nov 24th, 2007
Please can someone give me guide to configure cisco pix 515e for vpn to Symantec firewall:
The Symantec params:
DH group 1
Encryption : 3DES
Hash: md5
Urgent
Correct Answer by JORGE RODRIGUEZ about 9 years 8 months ago
Get 3DES/AES License to enable L2L vpn capabilities, once done refer to bellow link to configure the tunnel..
Sample config for l2l vpn, this is PIX to PIX using 7.x code but same principle if running 6.x code, as far as your end is concern you need peer IP address and ipsec information you posted as well as destination host you will be connecting to behind the other end to build tunnel access-list.. but mostly follow example bellow.. if problems after configuration let us know.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805a87f7.shtml
Pls rate any helpful post !
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Sat, 11/24/2007 - 23:05
  • Green, 3000 points or more
Jorge
