verify nat on asa
Nov 24th, 2007
device: asa 5520
how can i verify whether my nat is realy taking place aside from the sh xlate;
static (dmz2,outside) IPoutside IPdmz2
JORGE RODRIGUEZ Sat, 11/24/2007 - 22:21
you can do
show local-host IPdmz2
show xlate | inc IPoutside
beside these commands if your nat config is correct connection is another way to determined it is woring.
Rate any helpful post !
cfajardo1_2 Sat, 11/24/2007 - 22:44
but both of this shows translation is there even though theres no actual traffic taking place.
i wanted to know whether translation is realy taking place
cfajardo1_2 Sat, 11/24/2007 - 22:47
even though you do a clear xlate, and you do a sho xlate, it will still sh you the translation
JORGE RODRIGUEZ Sat, 11/24/2007 - 23:12
that means either the local host is receiving traffic from outside or generating-requesting outbound traffic by some app in host.. issue in pix enable mode PIX#clear local-host IPdmz , then do show xlate see if it still has translations.
Pls rate any helpful post
srue Sun, 11/25/2007 - 20:53
the 'show conn' command might help you on this also.
