Smart Serial & DB 60
Nov 24th, 2007
What is the difference between Smart serial and DB 60 WIC ??
Thanks.
Overall Rating: 3 (1 ratings)
jhhutchison Sun, 09/15/2013 - 11:06
There are many differences. The most relevant difference for someone concerned with building a lab for study is that the DB-60 connects to WIC-1T modules (installed into ISR routers) & the smart serial connector will connect to WIC-2T modules. The smart serial cable connector (correct this if it is misguided) the more recent form of technology as it provides two interfaces for a single slot when installed and it can attain higher port speed.
